Power steering question
Discussion in 'Technical' started by bryson123, Jul 31, 2018.
  1. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    So I am in the middle of getting my steering figured out and I noticed that there was major play in my steering so upon inspection I noticed that there seemed to be either like a hole or something has worn away on the power steering control valve. My question is do you think this could be fixed with a rebuild kit or do I need a whole new valve?
  2. Craig Selvey
    Where are the hoses that go to that control valve?
  3. Krazy Comet
    With system not operating there is some slop in the ball stud, that's mostly gone when pump pressurizes system..
    IF you're operating without the pump, the nut under cap on end of valve should be tightened till it's slightly snug, this helps prevent ball stud from jumping out of the valve.Thus loosing all steering. Also the valve should be greased(zerk fitting on bottom), this is important with or without P/S operating.
  4. bryson123
    bryson123 Member
    california
    All the hoses were removed but I have ordered all the components that I am missing. So is there suppose to be that big of a hole on the valve we’re the ball is? Most pics I have seekof them the ball isn’t even present is the hole suppose to b that big or worn away?
  5. Krazy Comet
    It's missing the dust boot, opening is normally a largeish oval.
  6. dyent
    dyent Member
    vancouver bc
    Where is the nut securing the ball stud to pitman arm or did you take it off?
    David
  7. bryson123
    bryson123 Member
    california
    I took it off pretty much took everything apart to see that the issue was so u think just a rebuild kit would be fine if it’s just missing that dust shield
  8. dyent
    dyent Member
    vancouver bc
  9. bryson123
    bryson123 Member
    california
    Does it matter if the control valve is made by Bendix?
  10. Krazy Comet
    They are all made by Bendix.
