Power steering to manual steer question
Discussion in 'Technical' started by JonnyRebel, Aug 1, 2007.
  1. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    1972 Maverick 4 door, 347 stroker, c4
    Theres a manual steering Maverick in junk yard here, and I want to convert my power steering car to manual steering. So.. what parts do I need to strip off off the manual steer car? Are any power steering parts reusable?
  2. 71gold
    drag link...pitman arm.
    ...:bouncy: ...
  3. Mavman72
    71gold meant center link/pitman arm.Steering box and colum are the same.Chuck the pump,ram and brackets in a box.Dont toss em,if you dont like manual steering you can allways switch back.If not sell the stuff someone will buy it(especially some one here):cheers:
  4. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    so I dont need the manual box.. just the pitman arm. and the drag link. what about that bracket that mounts to the frame or the tie rods? they the same? what about the idler arm? ugh i cant think of whats all there right now :hmmm:
  5. 71gold
    71gold meant...drag link...that and the pitman arm is all you need...:yup:
    ...:bouncy: ...
  6. Mavman72
    Refresh my memory 71? the drag link goes where and attaches to what??
  7. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    so all i need is number 4 and 7? (in the attached pic)
  8. Mavman72
    Yes correct.
  9. Jamie Miles
    The power steering box has a diffrent gear ratio and will make the car a little harder to steer in parking lots and what not. I have never found it enough to be a problem though.
  10. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    alright cool .. i thought there would be more differences :dance:
    now i can get rid of that dang power steering drop bracket, although its gonna require a torch because i welded it on with extra gussets after it broke and tore out the nuts in the frame and bent the steering ram.. good thing i was manuvering into the garage when it gave out or it woulda been bad.
  11. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    I read that the power box has a quicker ratio.. correct? I don't mind needing to crank on the wheel in parking lots
  12. 71gold
    [​IMG] Moog DS749 - Moog Drag link
    1968-72 Cars
    Drag LinkItem# 719-DS749 Only $69.99
    #4 in his pic.
    ...:bouncy: ...
  13. Jamie Miles
    Correct. The extra effort is really barely noticeable though. It's not bad at all.
  14. Mavman72
    We were both right 71gold. It is also referred to as "center link".:bouncy: I wasnt trying to step on your toes,just helping to make sure we give accurate info to those who ask.Terminoligy can sometimes be confusing.I consider the "Strut rods" on our cars as "drag links" Once again both terms are correct.It can be confusing though,dont you think??:cheers:
  15. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    i like to call it "that there bar that connects the the wheels to steer" or somthing like that. :drink:
