Power steering to manual steering
Discussion in 'Technical' started by 1moregear, Jun 27, 2009.
  1. 1moregear
    1moregear Member
    mississippi
    74 and 76 maverick
    Has anybody changed their power steering to manual. If so how did you like it? IT would be nice to not have to deal with all those hoses and control valves plus it would look a cleaner under there and give you more room. It`s the wife`s car she said could live without power steering and it`s a weekend cruzer car. Thanks for any input.
  2. Mavman72
    Manual steering on a mav/comet is the way to go IMHO...Paralell parking can be a bit tough but not so bad as one would think.Just converted my Sprint to manual and wouldnt have it any other way.Just dont go super wide on the front tires or it will feel like parking a dump truck when you have to swing that wheel around...
  3. nc73Mav
    nc73Mav Member
    Rockwell, NC
    Maverick
    i've been kicking the idea around of going to manual steering too. what parts needed when changing over?
  4. timers
    timers Member
    richardson tx
    1974 maverick
    I converted to manual some years ago and like it, and yes it parks like a truck, But when i nail it ,it go's in a straight line with no wandering
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    To convert power to manual, you need: manual steering box, pittman arm [mounts on bottom of steering box], and the manual centerlink. Some have used the power box just by changing the pittman arm and center link, but the steering will be a bit harder due to the different ratio's of the boxes. I have 215-60-15's on the front of mine, and it steeres pretty easy, except when sitting still. An even narrower tire would probably steer a bit easier.
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
  7. Maviboy
    Maviboy ForOnlyRealDrivers
    RICHMOND,CA
    74 Maverick,71 Comet
  8. sierra grabber
    northern nevada
    grabber you HAD? you didn't sell it did you?
  9. Maviboy
    RICHMOND,CA
    Sure did,ive been through about 5 Mavericks in the last few years. It was nice too 5.0 roller,t-5,9 inch detroit locker. 74,I converted it to small bumpers.Workin on a 64 Falcon now,5.0 with a t-56 tranny,4.56 gear 9 inch. Im gonna stop:nohijacking:,send me a message
  10. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    dose the mustang manual drag link fit mavericks
    was woundering if the 68-70 mustang steering stuff fits ower cars :huh:
  11. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    My first maverick I converted to Manual steering. No biggie except tight parking. Current maverick came with manual steering, again, no biggie. My only concern is once I get her running the way that I want and my daughter starts to drive it that she might have some problems with it. We'll see. (y)
  12. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    & this is a bad thing how ......:rofl2:
  13. jerry d
    jerry d Member
    Decatur, AL
    1973 Maverick
  14. Krazy Comet
    Steering sector is different, Mav uses the '68-'71 Fairlane, Torino, Falcon, Ranchero, etc box(larger and bolt pattern different different from Stang)... Mustang/Torino center links are too long but most of the other front end components are same... The '71-'73 Stang is basically same as '70...
    Size of tie rod ends and spindle/bearing changed from '69 to '70 models on all... Also applies to 69.5 Mav components are same size as other '69 intermediates...
  15. Mav06
    Mav06 Member
    El Paso
    1970 2Dr 200 c.i I6
    Hello everybody, I found a 66 Mustang part out locally and it comes with manual steering components. Can I use anything out of it to install on a 70 Maverick?
