Power steering to manual
Discussion in 'General Maverick/Comet' started by wolfheads, Oct 19, 2021.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I have a 73 maverick 302 at. What all do I need to swap from power steering to manual steering and does anyone have these parts ?
  2. dyent
    dyent Member
    vancouver bc
    You will need Manual Pitman arm from 70-74 here is link for part numbers, read the whole thread........
    http://mmb.maverick.to/threads/pitman-arm-question.98747/page-2#post-1154003
    look for stamping on manual pitman D0DA-3590-AB or D3DA-3590-AB
    the actual Ford part number is D0DZ-3590-A
    you will probably have to place an ad for a used one, as new ones are very hard to come by........
    you can try contacting these guys, do not know if they still have for sale or how much........
    https://www.rearcounter.com/D0DZ-3590-A-parts1377152.html
    and manual center link, which you can buy new.........
    https://www.ebay.com/itm/70-74-Maverick-71-74-Comet-Centerlink-Draglink-Center-Drag-Link-Manual-Steering/372691684830?fits=Model:Maverick|Make:Ford&hash=item56c627cdde:g:QC0AAOSwFs1cEuBv
    You can still reuse your tie rods and idler arm, if they are still in good shape and the power steering box, however it will be more effort to turn, since it has quicker ratio, 4 1/2 turns lock to lock compared to manual steering box which is 5 1/2 turns or more?
    David
  3. Krazy Comet
    Actually approx 3¾ vs 5½ for manual. Steering from stop will be noticable stiffer.
    You can buy a adapter/converter & retain your original P/S components.
    https://www.google.com/search?q=For...i22i29i30.20465j0j15&sourceid=chrome&ie=UTF-8
  4. 71gold
    CA189HJN likes this.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The adapter looks just like the original steering linkage on the 1926 Chevy I had. When I saw that I knew I wasn't using something that was designed during the dawn of the automotive age! It took some searching but I was able to scare up all the parts I needed.
  6. Craig Selvey
    Email me....I may have all the parts you need.
