...power to manual swap...
Discussion in 'Technical' started by 71gold, Jul 4, 2012.
  1. 71gold
    Collin and Tim came up in their Mav Tuesday. Jeff came down from Atl.in his.
    we had pulled a manual drag link and pitman arm from a '70 a few weeks back for this swap.
    we put Collins Mav. on my lift and pulled the power steering stuff off from under the car. then bolted on the manual link/pitman arm and then lowered the lift. from the top side we removed the power steering pump and hoses. swapped out the waterpump pulley and put a belt that Tim had bought for a...nonpower steering '73 Mav... the belt fit perfect...:thumbs2:
    no frontend alignment needed...:thumbs2:
    went to lunch...:Handshake ...thanks Tim...
    Jeff, Tim and Collin went home, I took a nap...:thumbs2:
    ...you know it...
    "A Large Time Was Had By All"
  2. blugene
    Curious. I thought I read somewhere that the gear ratios are different in the steering box ps to manual setups.. :huh:
  3. Big
    Big Member
    North Idaho
    So wish I lived closer... so you could help me break my maverick some more:thumbs2: Need a reason to put a bigger engine in sooner and transmission swap.. who needs a gas friendly daily driver :biglaugh:
  4. 71gold
    ...yes...is there a question...:huh:
  5. 71gold
    wasn't working on the...breaks...it was the steering...:yup:
  6. blugene
    How does the steering feel without having changed the box?
  7. the punisher
    the punisher Member
    Cobbtown, GA
    1973 2dr Maverick LDO
    It feels great. You can now feel the road.:drive:
  8. Earl Branham
    Lugoff, SC
    Gene, I have a power box with manual steering in my car. The manual ratio is 12:1, the power is 16:1. The only difference is the turning circle is a bit smaller, and the wheel a bit harder to turn at slow or no speed, and I couldn't even tell the difference on that. What I did like is that the steering is a bit more responsive at speed. Hope that helps.
  9. blugene
    Really? I would think the #s would be the other way around by your discription..
  10. rthomas771
    Power steering has 16:1 gear ratio...4 turns lock to lock
    Manual is 22:1...5-1/2 turns lock to lock
    I think Earl fat fingered the 2 and hit 1 instead
  11. blugene
    Ok.. These #s make sense to me..
    Brings me to wonder which box I have cause my first Comet had ps and the GT has manual. I remember swapping or changing the link but not why or which vehicle..
  12. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    So do all maverick/comet boxes fit all the years of cars?
  13. Earl Branham
    Lugoff, SC
    Yep, fat fingered the manual. Sorry!
  14. 71gold
    he also...butt dials...:yup:
  15. 71gold
    if you have a 14" or bigger steering wheel, there isn't much difference...(y)
    a lot of the floating in the steering is gone...:drive:
