problem after problem after problem...
Discussion in 'Technical' started by loki1911, Aug 19, 2005.
  1. loki1911
    loki1911 Lucky
    Milton, WA
    '73 Maverick soon to be grabber clone
    Trying to fix exhaust leak so we hadta pull off the manifold and then hadta get it resurfaced and then when they were doing that the heat exchanger tube snapped in half so now i hafta figure out a way to plug it or something? i need a quick fix cuz this is my daily drive...i hate exhaust:mad: i still havent even got a chance to figure out why the engine is running so bad or if replacing the thermostat fixed the overheating problem...school starts in 2 weeks oiiii i need help fast haha
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    YOu could use a compression fitting to repair the heat exchanger. If we are talking the part that goes to your choke to heat it up. Or use copper line to repair it. I did it on mine when I had the 200 ci strait six of unimaginable power in it......
