Problems with rear taillights
Discussion in 'Technical' started by justinc, May 17, 2009.
  1. justinc
    justinc New Member
    montana
    1972 comet
    I recently purchased a 72 Mercury Comet, and now I am having problems with the rear lights. All rear lights work when the light switch is off, but when I turn the headlights on I have no rear lights, turnsignals, hazards, brakes, nothing. Any suggestions??
  2. Jeff S
    Jeff S Member
    NoVA
    none
    Short in the light switch? Thatd be my guess.
  3. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    First thing I would do is clean all of the grounds associated with the rear lights. Then clean the light bulb sockets.
    Bad grounds will cause some strange problems.
    clint
  4. rayzorsharp
    Any chance you've installed an aftermarket stereo recently?
    If not, I would guess either headlight switch or turn signal switch.
  5. 71gold
    if it's just the..."rear taillights"...and not the ..."front taillighs" too...then i don't have a clue...:huh:
    ...:D...
  6. maverick4925
    maverick4925 Rust, Rust and more Rust
    Amelia, Ohio
    1970 Ford Maverick
    i had the same problem. i actually replaced the rear light sockets and they lit up fine. they are at autozone for about 4 dollars each.
