Proportioning Valve for Disc Brakes
Discussion in 'Technical' started by MaverickMagic, Feb 6, 2014.
  1. MaverickMagic
    MaverickMagic Member
    Charlotte, NC
    1973 Maverick
    I am changing my car to front power brakes and I already have the brake pedal assembly, firewall mount, and I can get the reproduction booster and master cylinder, but I still need a proportioning valve and lines. Does anyone know if there is a reproduction proportioning valve or will I have to get one from a donor? Also, if you have done this switch, what lines did you use and how did you set them up?
  2. rthomas771
  3. 55crownvic
    55crownvic Member
    colorado springs
    I used to get mine from a granada, but have since read on this site where the original prop valve works just fine, dont know if that is true, but am going to try that route with my current project. Wont be on the road for some time, tho. Do a search on here and see what pops up.
  4. Craig Selvey
  5. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    You can get one off ebay for under $50
