...pulley ???
Discussion in 'Technical' started by 71gold, Jun 13, 2012.
  1. 71gold
    a friend wants to remove the PS pump on his stock, 302 w/Air maverick....going to manual steering.
    we are trying to come up with a pulley to replace the pump.
    ...any suggestions?
    ...:Handshake...
  2. olerodder
    olerodder Member
    NorCal
    Don't really know what it looks like, although if it is similar to Mustang I'd use the steering pump bracket as a template, get some 1/4" or 1/2" steel or aluminum plate, tie it into the head, waterpump with spacers or maybe you don't need them................take the pulley off the pump, get a shaft. or make a shaft, then put some type of bearing in the plate.....oiless bushings maybe...............................................:bouncy:
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    460 Ford idler pulley might work
  4. 71gold
    too much like a job...but thanks...:Handshake
    looking for something a little more simpler.
  5. 71gold
    :yup:...something like that...:thumbs2:
  6. jmgford
    jmgford Member
    Iowa
    Loop the hose on the pump.
  7. 71gold
    maybe to start with, until we find a pulley...:yup:
  8. Joe Dirt
    A/c tensioner pulley on a homemade pate easy squeezy
  9. 71gold
    may have to go there later...:Handshake
  10. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Just use a smaller belt? Not really sure where the PS pump pulley is but if nothing else major is attached to it theres no need for a replacement.
  11. 71gold
    had thought of that but are other things plus the pump is the tensioner for that belt...
  12. Craig Selvey
    Why would you need to replace the power steering pump with a pulley? The power steering pump has it's own belt....just leave it off. :huh:
  13. baddad457
    You've got to have a way to put tension on the belt. The P/S pump was that way, the A/C compressor is mounted stationary. He just needs an ajustable idler pulley like what's pictured above.
  14. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    I beleive i have one of those p/s delete idler pulleys. It was on grabbergts mav when i bought it.
    Your friend is welcome to it if he'll pay shipping.
    ray
  15. 71gold
    Hi Ray,:Handshake
    that sounds like just what he needs...:thumbs2:
    got a pic. of that P/S delete idler thingy?
    I see our join date is almost the same...:cool:
