...Purty on wheels..
Discussion in 'General Maverick/Comet' started by 71gold, Mar 26, 2007.
  1. 71gold
    test drove it yesterday...:bananaman awsome!!!
    thanks Mike :Handshake
    going to try and get it buttoned up this week and hit the road this weekend...:drive: :burnout:
    Motor Build for...Patches...1973 Ford Maverick Grabber
    Block-1987-FORD Mustang-5.0
    Align. Honed
    Bored- .030...306 c.i.d.
    Crank-Stock-1987-5.0- .010/.010
    Bearings-Seal Power
    Pistons-Hypereutectic-Flat Top-4.030in.
    Rings-Hastings-Chrome
    Rods-Stock-Resized-ARP Bolts
    Balanced-0.2 oz-in Target
    Compression-9.5:1
    Oil Pump-Melling-Standard
    Oil Pump Shaft-ARP
    Fuel Pump-Summit-80 GPH
    Timing Set-Comp Cams Magnum Double Roller
    Water Pump-Advance Auto-Standard Rotation
    Headers-Hooker 6901
    Cam Specs.
    Cam-Trick Flow Track Heat-Hydraulic Roller
    Firing Order-351...1-3-7-2-6-5-4-8
    Duration-Intake 275/Exhaust 279
    Lift-Intake .499/Exhaust .510
    Lobe Seperation-112 Degrees
    Cam Advanced-4 Degrees
    Roller rockers-Crane Energized 1.6
    Lifters-Stock 5.0- Roller
    Push Rods-Ford Racing-5/16 in.- Hardened
    Heads-Non Emission
    SBF-AFR 165 Outlaw Street/Strip
    Combustion Chambers-58cc
    Rocker Arm Studs-3/8 in.- Screw In
    Guide Plates-AFR
    Valve Job-3 Angle
    Ports-CNC Ported Intake/Exhaust
    Valves-1.90 Intake/1.60 Exhaust
    Valve Guides-Bronze
    Head Bolts-New- Stock
    Intake-Edelbrock Performer RPM
    Carb.-Holley 4160c-750 CFM- 4v-
    Vac. Sec.-Electric. Choke-Polished
    Coil-Pertronic Flame Thrower
    Dist.-Stock Ford- w/Crane Cams Hardened Gear
    Dist. mod.-Pertronic
    Plug Wires-MSD 8.5mm-(RED)
    Spark Plugs-Autolite-AR3924
    Dist. Cap-MSD-(RED)
    Harmonic Bal.-Ford Racing
    Gaskets-Fel-Pro
    Transmission-1984-f150-AOD
    Rearend Gear-3.55
    Posi. Traction- Powertrax
    Dyno Results-EngSpd RPM---NR--- -WhlPwr HP---NR---
    WhlTrq lbs-ft- ---NR--- -Speed MPH---NR---
    The Crew
    Motor Specs. by- Mike A. Vaughn...Thanks...(M.A.V.)
    Machine Work by- Wheeler Machine...Thanks...Wesely Grimes
    Rotating Assy. Bal.- Walker Performance...Thanks...Chris
    Motor Build- Harold Etheridge
    To be Dyno by-Reeves Performance...
    Special Thanks to......
    my Loving Wife...Effie Cooper...Thanks...(Sweetie) XOXOXO
    Mike and my motor...:cool:
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Good for you, Frank!
    Good work, guys.
  3. 71gold
    stopped to get gas...a guy walked over...looked down at the motor...and asked....................what color you going to paint it :slap:
    ...me and my...gas operated engine stand...:cool:
  4. Rick Book
    Rick Book Member
    Thailand
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Good job Frank, Effie and company. I like the way that A/C compressor looks on there. I have to get one!
    Seth
  6. scrapper60
    scrapper60 MCCI Member
    Alabama
    Pray tell, what did you do Frank? Supervise?
    Great work Effie and crew!!!!! LOL.
  7. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    The car sounds great ,and runs Good too ...Frank squeezed into it at around 15 mph or so and it proceded to effortlessly haze the tires:burnout: for about 20 feet... Frank looked like this ---> :character0182: Then when he pulled it back in the yard and got out like this--->:D
    And THAT is what its all about!:dancing:
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    congrats Frank, Effie and crew......so Frank, were you heading this weekend? :huh:
  9. rayzorsharp
    Geeze...sure hope this is not your new signature!!!
    J/K Look forward to seeing it soon.
  10. Dave B
    I sure wish my wife would go out to the garage and finish my car for me :)
  11. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I'm green with envy...
  12. NICK DOMINICK
    Burke, Virginia
    Frank, that is awesome!!!! How did you get Travis Tritt to come over and help?
  13. don graham
    knowing your quality, i'm sure it looks great effie (i mean frank). looking forward to seeing it in person.:thumbs2:
  14. mavtricks71
    mavtricks71 Member
    where did you mount the dryer for the a/c?
  15. das351965
    das351965 Member
    sc
    2-71 mav 1-71 grabber and 75 4dr parts car
    nice job. need pics of all this
