Pusher or Puller
Discussion in 'Technical' started by Scotty P, Jun 26, 2007.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    I mocked up my new electric fan tonight and found I could go on either side of the radiator w/o issues. I like the idea of "hiding" it on the outside like Dennis did, but wanted to get the most cooling from it as possible. So, what works best? Pulling or pushing.
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Pulling is more efficient. Not gobs and gobs, but a fair amount.
  3. don graham
    try whichever you like best. if it cools enough leave it there. if not try the other. usually a puller fan is more efficient.:)
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    Thanks, Perma cool said about 80% less efficient but I wanted "real world" answers!
  5. Grabber5.0
    Kansas City, MO
    71 Grabber
    Do you mean 80% less efficient or 80% efficient? :hmmm: I would think 20% loss is reasonable.
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    20% less, 80% as...
  7. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    If you have the room, puller is the way to go:thumbs2:
  8. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I'd go puller if you can. Always worked better for me.
  9. scooper77515
    In all the fans I have used, I opted for puller due to the noise the fan makes...of course, this depends on the shape of the blades. I think...THINK...straight blades will be quieter as pusher/puller, where curved blades are made to run a specific direction, and will be louder going the "wrong" way. I had a puller installed as a pusher once, and it sounded like an airplane going down the road...
  10. Scotty P
    Scotty P Member
    santa rosa, ca
    Puller it is. Thanks
  11. Acornridgeman
    Wisconsin
    I saw your title and thought maybe you were buying an RV ....... :)
  12. stmanser
    Davenport, Iowa
    i always thought that if the fan is on the outside of the car, and the air rushing through the fan blades will push the blades the opposite way that they spin, therefore slowing the fan blades down, it would make them not very efficient.....but at highway speed, the air rishing is just fine vs a fan anyways..
    every car i have seen with a fan, has the fan on the inside of the radiator, pulling the air through... it comes that way from the factories... so it must be the correct way to do it
  13. scooper77515
    "correct"?:D
    C'mon Simon...you know there is no "correct" way to do anything with our Mavericks:p
  14. Mavaholic
    I have always heard that puller is more efficient, however, logically I dont see the difference. Fact is, fan blades are designed to turn in one direction to be most efficient. Making something universal is always a trade off. Since the majority of people hook them up as a puller, probably because thats the easiest way to do it, I'd say the fan is designed to be most efficient in that direction. I'd bet thats the reason for the difference. I believe a fan could be just as efficient as a pusher if it was designed to run that way. Just my thoughts.
  15. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Saw a good bumper sticker on a jeep (it was following very close,3', a motor home)
    Please be patient, I'm pushing as fast as I can!
