puzzled by electrical problem
Discussion in 'Technical' started by vern, Jun 17, 2007.
  1. vern
    vern Member
    New Jersey
    Got the mav on the road and tonight took our first moonlight drive..Well every thing was fine until I used my turn signal.. The signal would light up but would not blink..When I got home turned off the headlights and the signal would blink fine but with the headlights on it would just light up and not blink..This was with both left and right turn signal...Seems to be a low voltage problem but where would I start I am lost on this one..
  2. Mavaholic
    Probably a grounding problem. They always do weird things.
  3. PaulS
    Look at the ground for the turn signals it seems to be grounding through the headlights.
  4. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    maybe your fuse...i had this happen to me, but only with one blinker...gl with it
  5. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    It's probably one of your front turn signals. Since they get their ground through the bracket that connects to the bumper, that connection can be lost if corrosion occurs between the bracket and bumper. (I'm talking about the early style front turn signals..the later ones in the grille have a separate ground wire I believe).
  6. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Are the turn signal lamps on when the lights are on?
    If that is the case, you could be feeding the 12V signal from the headlights back through the blinker circuit, which would make them on all the time. The dash light would be solid on when you engage the switch. The "flasher" box in the fuse block relies on a voltage difference between the 12V supplied to it and the load on the lamp. If there are 12V on both sides of the flasher, then there is no voltage difference to make the flasher work.
    Since you just did a resto, I would check to make sure that the blinker circuit is seperate from the headlights and marker lamps.
