I was just wondering what your whole engine combo is? I would like to get my comet running somewhere in that range some day. That is if you want to maybe you don't want to give away you secerets Thanks, Derek
well here goes the block is a stock 302 roller block std rods & mains stock crank eagle sir rods bushed TRW .030 dome speed pro rings ford windage tray kit(check the 3/8 rod bolts eagle they will hit this tray) (seal the pan bolts with this tray) milodon front sump 8 qt oil pump high volume runs 80 lb cam is a comp solid roller 35-771-8 AFR 185 heads with manley valves comp springs 1.6 roller rockers 3/8 RPM dual plain intake 600 holley HP 72 jets with a ram air kit made in canada all MSD 40 LOCKED on the timing i build my c-4 trans (working on a roller c-4) drums are 5 clutch drums trans go shift kit R-servo no brake 8" dynamic covt 4700 stall with a 370 gear 9" (355 to 370 gear with this comp cam) i shift at 6400 rpm AMS in bossier city La does all the machine work for me 308-222-7889 ask for Raymond if i can help anyone just e-mail thanks ivy
