Question on my 73 comet switching trans
Discussion in 'Technical' started by 73cometter, Apr 19, 2020.
  1. 73cometter
    73cometter Member
    Maryland
    73 Comet GT
    I have a 73 Comet with 302 motor and 3 speed manual trans, want to switch to a c4 trans, what all would needed.to do this
  2. Krazy Comet
    Find someone who has one with auto & wants to switch to manual.
  3. Craig Selvey
    You are going to need:
    1. C-4 Transmission
    2. Transmission kick down rod (and possibly the linkage at the carb to hook it up.)
    3. Radiator (Yours might now have provisions for transmission cooling)
    4. Transmission cooling lines to radiator
    5. You will have to "T" into the vacuum on your engine manifold to run a vacuum line to the transmission
    6. Some time of shifter and associated parts in order to shift the transmission
    7. Possibly a different speedometer cable, and I think for certain, a different speedometer gear on the end that goes into the transmission
    8. Engine flexplate instead of a flywheel
    9. Neutral safety switch and associated wiring
    Just a quick list off the top of my head.
