Quick question.
Discussion in 'Drag Racing' started by courier11sec, Jun 20, 2007.
  1. courier11sec
    courier11sec Member
    Tucson, AZ
    My NHRA rule book is out dated. A buddy told me when running slicks all cars need long wheel studs and a five point harness. I've run slicks before and had neither and tech didn't say a word. I thought the requirement was open lug nuts and a driveshaft loop.
    Can someone have a look in this years book and straighten me out?
    Thanks.
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I don't have a rule book, so I use Don Graham. :) The last time I checked with him (2006, don't think I checked this year), you do not need open end lug nuts, they just have to engage at least 1/2" of thread (for 1/2" studs) - the rule stated (paraphrasing) it has to engage an amount of threads equal to the diameter of the stud. Driveshaft loop is a requirement for slicks or faster than 14 sec (at the time). Five point harness does not come in until well faster than 13 seconds).. I'm thinking 11's somewhere.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I think the point of the open end lug nuts is so they can visually see that the stud is long enough. Without them you would need to remove a lug nut to see.
  4. don graham
    you don't need a harness until you run faster than 11.49. and here in division 7 you don't need to update the harness every 2 years, as they finally realized an outdated 5 point harness was still safer than the legal 30 year old lap belt.:)
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I'm glad someone finally figured out that these belts don't explode at 2 years old! I thought that just happened in Mission Impossible episodes. Anyway, I hadn't heard that one Don, but that was one of my biggest pet peeves with NHRA. When I was first starting out in racing it was costing me too much just for belts every two years. Now after that rant I will say that they are just looking out for us I suppose. It's a lot easier to run low numbers now than it was 20 years ago.
  6. don graham
    mine were outdated in october of last year. i checked with the nhra tech director before the et finals to make sure. they check every time i go through tech and just drop the belt. :)
  7. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Maybe he just likes your smiling face?!? :rofl2: I seem to offend tech guys! :cry: I really need a hobby...
  8. 71gold
    so your answer amounts to...you don't know the answer...:D
    ...:yup: ...
  9. igo1090
    igo1090 Member
    catonsville, md
    IIRC when you must have a roll bar, the harness is required with it.
  10. don graham
    dave, do they do like division 7 does for bracket racers back there. if you don't go faster than 11.49 you don't have to get the belts recertified? just curious as to wether i'll have any problems in ky. or va.:)
  11. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i dont believe thats the case with Mason-Dixon...or at least i certianly hope not:cry: i have a 5 pt but no cage...yet...
  12. Grabber5.0
    Kansas City, MO
    71 Grabber
    If Don didn't lie to me, then I do know the answer. :p I think I trust him. :D
  13. Just Jim
    Just Jim Member
    So Cal
    '72 Comet '62 Falcon '58 Morris Minor
    I race divsion 7 and had to change the 5 pt belts in my car last month because they were 2 years old. If the 2 year rule isn't in affect anymore then somebody at NHRA should let the tech guys at LACR and Irwindale know about this.
  14. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    I'm guessing what Don means is that if you don't need a roll bar then you don't need the harness re-certified every 2 years. I know guys that use a 5 point harness even though they could have kept the stock seat belts. The tech guys were making them get the belts re-certified just because they had a 5 pt racing harness. For example, Don goes high 11's and isn't required to have a roll bar and harness, but he does anyways (cause he's smart). Since he isn't faster than 11.49 he shouldn't need the certified belts.
  15. don graham
    just jim, tell them to get ahold of ben wilson. the tech inspector for div.7 his number and email are in the front of the national dragster. i talked to ben personnally. just remember that tracks can make their own rules. also i'm sure this dosent apply to the lodrs or the powerade series. just local brackets.:) ben's # 520-579-1426, tues & thurs. 7-9p.m., email benwilsond7@aol.com . hope this helps. p.s. like erik said this only applies to those cars not running faster than 11.49.
