quicker auto transmission???
Discussion in 'Technical' started by TreyF73, Oct 19, 2007.
  1. TreyF73
    TreyF73 Member
    Ohio
    1973 Mercury Comet GT
    I have an automatic transmission and i was hoping to quicken up the switching of gears so it gets more of a jump and is quicker..how do i do that?:huh:
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Band adjustment?
  3. scooper77515
  4. scooper77515
    This mod will make it shift from gear to gear more quickly. If you are asking for it to shift at a lower rpm, then you will need to swap or adjust your vacuum modulator.
    Just clarifying depending on what you mean by "quick shift"
  5. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    35 dollar shift kit. and tighten the bands. I did it and works great.
    Cheap....easy....effective
  6. TreyF73
    TreyF73 Member
    Ohio
    Where did you get the shift kit?
  7. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
  8. Craig Selvey
    Yes....you can change the gears. It requires dissasembly of the tranny. I had it done to my car at the rebuild.
  9. Mercurycruizers
    Venetia, PA
    That tranny had a shift kit installed in it, when I first bought the car. It still has the stock torque converter. I always shifted it manually, that way I could whine it out if I wanted to. You also still have the stock 2:79 gears in the rearend. It has been years since the trans was rebuilt. So, you might want to rebuild & install a new shift kit. When I had 3:55 gears in the rearend, I could get it to break loose in 1st & chirp the tires in second....(y)
  10. PaulS
    There is a thread in the Tech Articles forum on how to hot-rod your C4. The last posts are on how to modify the valve body to make it shift quicker and make it better for performance and to extend the life of your tranny. The mods will not make an old tranny new again but it will make it shift better if it is in decent condition now.
  11. TreyF73
    TreyF73 Member
    Ohio
    Anyone know a good place to get 3:55 gears?
  12. scooper77515
    JEGS, Summit, etc. They aren't too expensive.
    Or are you trying to buy the entire carrier already equipped with 3.55?
  13. awannabegrabber
    Wichita, Kansas
    Orielly's
    also i put in a Rachet shifter and that seemed to help with a quicker shift. less movement.. but you have to adjust them cables just right.
  14. TreyF73
    TreyF73 Member
    Ohio
    everyone has told me to adjust the cables but i have no idea how to do that. lol.
  15. newtoford
    newtoford Member
    New Castle Delaware
    ive been following this thread since i want to get a shift kit myself but i do feel slightly intimidated since ive never really been inside an automatic trans to make any adjustments or modifications
