rear axle problem
Discussion in 'Technical' started by anton1, Mar 16, 2009.
  1. anton1
    anton1 New Member
    Colorado
    1973 Maverick
    I have a 73 mav and the rear axle is not centered in the car from side to side. Has anyone seen this problem and know how to fix?
  2. Mavman72
    What makes you think its not centered???.Common cause is broken leafspring U bolts...check em out.
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    post some pics...
  4. baddad457
    Mine's not centered either. It's offset to the passenger side by about a half to 3/4 inch. Not the only Ford I've had either with the same offset. My 89 Ranger is as well, as was my 68 Merc Monterey.
  5. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    offset
    How exactly did you determine that it is not "centered" ? What points of reference are you using? May have some bearing on whats wrong..or not wrong..
  6. rthomas771
    What are you calling side to side? Left side/right side? Sticks out farther on one side from the leaf spring than the other? Closer to the door on one side than the door on the other side? You got to remember they didn't have robots putting these cars together...they had a guy on one side and a guy on the other side and they couldn't see what the other guy was seeing.
  7. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    some times people replace the rear quarter panels and do a bad job at lining things up that can make your rear look off center
    brad:)
  8. baddad457
    Simple, you can measure the distance to the fender lips. ;)This gets easier the wider the wheels and tires. Also makes clearance here more critical. If you're running skinny tires and wheels, don't worry about it.
  9. baddad457
    The rear quarters on mine are original and undamaged. As were the ones on my 68 Merc and 89 Ranger
