Rear axle question. Again
Discussion in 'Technical' started by Banta, Mar 27, 2015.
  1. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Found this online and was wondering if it would fit my stock 72 axle. It says it's for 62 to 77. But I want a second opinion Screenshot_2015-03-27-06-41-32.png
  2. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
  3. rthomas771
    5-lug axles or axle bearings for a 8" housing won't fit a 4-lug 8" housing. The axle tubes are different size diameter
    Krazy Comet and Banta like this.
  4. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    OK thank you
  5. Krazy Comet
    Good to know, thanks...
    Means I can pull the pumpkin on the '71 and scrap the remainder...
  6. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Will a Mustang rear fit with Minimal work? I seen where the Explorer would work if I was to cut one side down. But I don't have access to the tools I'd need for that yet
  7. rthomas771
    Actually it's the tube ends around the bearings that are different. If you happen to have a '71 5-lug then it is the narrowest Maverick housing. The '71 rearend I have measures 55-1/2" flange to flange. I'm thinking the 72-up 5-lug rearends measure around 56" or 56.25"
  8. Krazy Comet
    I'm referring to the '71 GT parts car I have, never pulled a hubcap to see how many lugs it has... It's a orig 200 6cyl car and has a four lug spare, 99.9% they'll be four lugs hiding under the caps...
  9. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    What all rears will fit without having to modify it. Other than moving spring perches? Don't have to be disk brake. I'm just wanting 5 lugs. I don't plan on racing it and just having disk in the front seems safe enough for me. And is there just a 5 lug hub out there somewhere that will fit? That might be a more walet friendly alternative
  10. 71Mavrk
    71Mavrk Member
    Nevada
    71gold and Banta like this.
  11. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    The Timken bearing for a four lug axle is #2018 and the bearing for a five lug is #2024.
  12. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I'll check into it. But haven't had any luck yet. Thanks for the list. That helps out alot
  13. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Think I might have one. If the guy still has it when I get up there. Found a granada rear for 75 bucks
  14. Craig Selvey
    A Granada rear end is slightly wider than a Maverick rear axle....but should work.
  15. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    My rims are fitting pretty good now and it has 1 inch adapter plates on each side. So I don't think I'll have to worry about my rims backspacing
