rear end four to five lug
Discussion in 'Parts Interchange' started by GEO, Aug 12, 2004.
  1. GEO
    GEO GEORGE STAVROPULOS
    Dearborn, Mich
    1973 maverick grabber, 1972 v-8 grabber & 1971 Maverick six 3 on column, 70 Mustang 302 Convertable, 1996 f-150, 1992 Taurus L
    Question:
    I have a 1971 Maverick with a 200 six three on column and want to upgrade to a five lug set up, could i just replace the 3rd member / pig and axle shafts or do I need to replace complete housing as well and if so why?
    anyone?
    Please help, George
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    You need to replace the entire housing. 5-lug axles use the large bearings ... 4-lug uses the small bearings ... the housings are different for the different size bearings ...
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    also if i remember right, the later 5 lug rear has bigger drums...bigger brakes!
  4. michael porter
    michael porter Member
    oklahoma
    1971 maverick with 4 wheel drum..200...3 on the tree...just painted it white...runs great even after sitting 10 years...needs interior work...fun car to drive
    can the granada 5 lug rear fit nice and easy into the 71 mav for a simple swap or is there more to it?
  5. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have read on other posts that the Granada is direct bolt in. As far as simple,, dunno. I find that the only thing simple in life is getting myself into trouble lol.
    Dan
  6. tony4eight
    tony4eight Member
    I just bolted a1979 granada 5 lug in a 1970 grabber and it bolts up fine but thats as far as i've got so far
  7. 73infla
    73infla Member
    north port fla
    1973 ford maverick 4dr
    i have a 73 maverick, and the engine winds real tight at 65 mph. here is my ?. since i can turn the rear wheel 1 full revolution and the driveshaft turns only one revolution, what is the gear ratio and what can i do to bring the engine rpms down so i can cruise up the i-state at 75 like i want to? what gears can i put in, or can i install an aftermarket o.d.???
  8. doctorofmotors
    doctorofmotors New Member
    winds real tight?
    hey 73infla,
    other than counting the teeth on your gears, the best way to know your rear ratio is to make a 'dot' on the tire and a 'dot' on the driveshaft (paint, chalk), and roll the car on the driveway one complete revolution of the tire. have a friend count the number of drivshaft revolutions at the same time. pain in the neck, but you should be able to get the ratio within about .20. for example: 3and1/4 driveshaft to one tire revolution=3.25 gears. ok?
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    That method has never worked for me...don't know why. I always count the teeth if there is no tag with the gear ratio stamped on it...
  10. 71gold
    73infla, said his driveshaft turns (1) to (1) with his tire . would that be 1.00:1 gear ratio? if he could get the car rolling he would be doing..1000 rpm @100 mph :eek: . just a guess, someone do the math...frank...
  11. 73infla
    73infla Member
    north port fla
    i understand the whole 1 to 1 ratio, but that still does not explain why the engine is screaming at 60mph, i need some one to break it down for me----i never have been any good with the ratio stuff all i know is when it breaks, i have to fix iti do not have a rpm gauge so i cannot tell what the rpms are i only know that the engine is revving way too high. thanks for the explanation
  12. 73infla
    73infla Member
    north port fla
    this is the first rearend that ive ever had to mess with
