Rear End
Discussion in 'Technical' started by mouth01, Jan 24, 2005.
  1. mouth01
    mouth01 New Member
    Shawano Wisconsin
    1974 Maverick
    Did a 1974 grabber Maverick come with an 8" rear or was a 9" rear an option also?
    Scott
  2. Mavaholic
    8" was the only rears put in these cars except for the very early 70 which had a 7.5.
    The 9" was never an option.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You can get a 'bolt in' 9" out of a Granada/Monarch if you so desire.
    It is 1/2" wider per side, but everything else is identical. So if you don't have huge tires or custom rims with an extremely tight offset, the width is not noticeable.
    Dave
  4. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    what years granada/monarch?
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    So all mavericks & comets have a 8 inch rear, RIGHT.
  6. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    70 - came from the factory with 7.5
    71-77 - came from the factory with 8.0
  7. Kilg0re
    Kilg0re Doh!
    my blown up rear end is a 7.5 and i got 70.... I thought 71-77 only v8's came with 8"?
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Please refer to Mavaholic's and Todd's post ...
  9. Kilg0re
    Kilg0re Doh!
    link?
  10. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks Todd, I needed to know that.
  11. ratio411
    ratio411 Member
    Pensacola
    All of the first generation Granada/Monarchs were available with 7.5", 8", and 9" rears. I want to say 75-81 were the years. I got one from an 81 Monarch in a junkyard. They charged me 80 bux because their computer only showed an 8" as available in Monarchs and that was their flat fee for an 8".
    The second gen Granadas were Fox platforms and use coil springs out back, and 4 lugs.
    Dave
  12. chandler
    chandler Member
    Warrenton Mo
    Maverick
    If you are lucky enough you can still find the early 9 in rear ends that are the same width as an 8"
  13. Mavaholic
    Not all 70's had the 7.5
    Only the 69.5 had them. The rest of them had the 8" from what I've seen.
  14. Craig Selvey
    My 1970 Grabber (now Dave Ring's) has the 7.5" rear. It was built in April of 1970.
  15. maverick1970
    maverick1970 MCG State Rep
    Missouri
    My 70 originally had the 7.5" in it. It now has an 8" out of a 72 Grabber
