Rear frame/spring hanger fab-info,who's done it?
Discussion in 'Technical' started by Powerband, Jan 10, 2015.
  1. Powerband
    Powerband Member
    NY's \H/
    I need to address the rear frame rails and rear spring bushing carrier. I could use some hands-on fabrication discussion or links to available posts on fabrication or adapting similar parts , originality is not a concern.
    thanks
    "before"
  2. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    Looking at this, how is the shape of the rest of your car?
    I think a donor maverick will need to be purchased or if someone who is parting out a maverick is willing to remove this section for you.
  3. scooper77515
    OUCH! Looks nasty!
  4. Craig Selvey
    Not to be a Debbie Downer.....but looking at the rest of your pictures....you also need front torque boxes, floorboards, and full rear quarters.....all for starters. It is not just the rust you see.....but all the rust you DON'T see. I think many would suggest (myself included) that you would be MILES ahead by finding another car.
    See this:
    Fix THIS not THAT: http://mmb.maverick.to/showthread.php?t=86787&highlight=fix
    mojo likes this.
  5. Powerband
    Powerband Member
    NY's \H/
    Thanks for the replies,
    More info appreciated especially pics'
    ... someone who is parting out a maverick is willing to remove this section for you.
    That is one way to go, this could happen but fabb'n from square tube or similar rear rail application probably easier and less expensive since originality isn't important. Available Mustang rails may be adaptable .
    ... you would be MILES ahead by finding another car.
    ... probably true , and the guy who sold it to me thought that way, 'guess I'm not ready to let any survivor and titled orphan car be junked so readily.
    have fun
    my other Comet:
    [​IMG] . [​IMG]
  6. scooper77515
    Sorry, dude, not trying to scare you away from mavs and comets. But many of us have experience in where the rust hits, and you might want to look deeper into this car and see where you have nastiness.
  7. scooper77515
    OK, you posted last post while I was typing mine. You do good work....
    Keep it up!
    Is that POR-15?
  8. Craig Selvey
    If you did the work to that Comet....you have some mad skills. With that skill level....then your current Comet will be in good hands.:Handshake:
  9. 71gold
    why the questions in post one...:huh:
  10. Powerband
    Powerband Member
    NY's \H/
    I'm new to late model Mavericks, Finding info to try to fix rather than scrap a '76 . So far no real info on available rear frame rails/spring hanger. I think I found they use specific channel and bushing dimensions?. Maybe just cut/adapt and swap easily available Mustang or Fairlane parts - if they are close to spring size... ?
    Any info appreciated - '76 Six car :
    Need : Spring width - eye dimensions - , bushing dimensions etc
    Mustang rear rails
    http://www.macsautoparts.com/ford_m...il-section-right-30-long-all-body-styles.html
    thanks
  11. tody
    tody Member
    cologne, germany
    bushing size is an issue.
    1" outer diameter on the maverick opposed to 1 3/8" on the mustang.
    inner diameter should be identical with 1/2", though.
    thus you should be able to get away with mixmatching parts.
    width should be identical with 2 1/2" wide springs.
  12. Powerband
    Powerband Member
    NY's \H/
    Thanks,
    ' might be able to use a pair of the Mustang spring eye section if spring width matches and just use 'stang bushings.
    .. additional info or discussion on rear rails/hanger and pics appreciated.
    have fun
