Rear leaf springs-all the same?
Discussion in 'Parts Interchange' started by Shadylane, Sep 24, 2013.
  1. Shadylane
    Shadylane Member
    Farmington, New Mexico
    77 Maverick 302 4 door
    Will the rear leaf springs interchange on all the V-8 cars? I was looking at the Cal Trac web site and the only show their split Mono Leafs for 1975 and earlier cars. I thought they were all the same. I have a 77.
    Kelly
  2. scooper77515
    I think they all interchange. Some have different shackles, but even those interchange.
    Maybe they think the different sized shackles mean they won't fit??? :huh:
  3. Mercurycruizers
    Venetia, PA
    I swapped leaf springs & rearend from a 74 4 door Comet, to a 70 Maverick Grabber 2 door. It bolted right up....
  4. wmcover
    wmcover Member
    1970 maverick, 200six
    Some have four leaves instead of three, but I don't know why. They will still interchange, I believe Granada ones work too.
  5. Dave B
    The 4 leafs were part of the heavy duty suspension package.
  6. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I've also saw 4 leafs on 4 door cars.
  7. wmcover
    wmcover Member
    Interesting! Seems like on a car it would be a sport or gt package, HD springs sounds trucky? Lol. Four door makes sence as they are longer and heavier bodies... hmm.
  8. rthomas771
    You can't go by leaf count. The factory '77 3-leaf HD spring were rated at 779 lbs. The factory '70 4-leaf HD springs was rated at 535 lbs. '71-'73 HD 4-leaf was 708 lbs. Big bumper cars with more options have a higher spring rate than a skinny bumper cars. 4-Door had a higher spring rate than most, but not all, 2-door models. According to the Master Parts Catalog, between 70-77 they were about 25+ different part numbers for springs for the Maverick. http://www.dixiemaverick.com/DMleafsprings.html
  9. Mercurycruizers
    Venetia, PA
    4 door cars had 4 leafs cause they were heavier. My 70 Grabber now has 4 leaf, instead of 3 leaf.... Gives it a slight rake. I like the stance now....
  10. wmcover
    wmcover Member
    *LIKE* !
    great post and very informative! Thank you!
    (y)
  11. Shadylane
    Shadylane Member
    Thank Folks for the info. Lot's of interchange options especially if you throw in the Granada springs.
  12. rthomas771
    The Granada spring will put the rear end 1/8" closer to the rear bumper which will effect on the driveshaft length. The Granada is heavier than a Maverick so the springs will be stiffer.
  13. Blue Brick
    Blue Brick Member
    Reproduction Leaf Springs - J.C Whitney
  14. 71gold
    never seen a...5 leaf spring...on any Mav/Comet...:huh:
  15. Blue Brick
    Blue Brick Member
    75 to 80 is a G/M.
