Rear lower shock mounts
Discussion in 'Parts Interchange' started by azarembo, Mar 14, 2015.
  1. azarembo
    azarembo Member
    SE Michigan
    1990 Mustang LX
    Does anyone know if the inline (1970) lower rear end shock mounts interchange with any other cars? Possibly a falcon or similar? Anyone have a part number for the inline shock mounts?
  2. tody
    tody Member
    cologne, germany
    does the 70 model have staggered shocks?
    you might want to look at the 67 and up mustang shock plates, they should fit.
  3. mav1970
    No Thomas, the 69.5/1970 model has the in line shocks
  4. rthomas771
    The shock mounting tap on the Mustang plates have a lesser angle than a Maverick mounts. The Maverick plates are almost 45*. This angle differences might mess you up mounting the shocks to the spring plate.
  5. Krazy Comet
    RH . D0DZ-5796-B
    LH . D0DZ-5796-A .. These are Maverick specific numbers...
    Number for RH is same for '71, but LH is different I believe because of staggered shock mount...
