Rear Seat Removal
Discussion in 'Technical' started by aubman82, Mar 18, 2009.
  1. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    Would like to replace the seatbelts in my 74 Mav. How do you remove the rear seat?
  2. 71gold
    kind of a...down-back-up motion to the rear seat bottom (front edge)..there is a hook style bracket on the floor pan.. once you get it from then on it's a piece of cake...:D
    ...Frank...:Handshake
  3. 71gold
    once the bottom is out, there are 2 bolts at the bottom of the back part of the seat. after removing the bolts, slide the seat up out of the brackets at the top...:yup:
    ...Frank :Handshake
  4. justin has a 74
    kentucky
    its like a LETS RIP IT OUT motion back then forward
  5. fordmaverick72
    fordmaverick72 Member
    Milwaukee, wisconsin
    1972 ford maverick 302 30over aod with 8.8
    seat removal
    the first rsponse worked well i just used it took about 3 minutes to do.
    NOTE: the bolts hold back rest on rear reats was 3/8.try using deep socket works perfect.
    thanks
