Rear tail light harness question
Discussion in 'Parts Interchange' started by Jean Doll, Dec 11, 2005.
  1. Jean Doll
    Palmerton, PA
    Hey all. I have a perfectly good rear tail light wiring harness from a 72' Mustang Mach 1. Will it interchange with the ones for our Mavericks?
  2. Acornridgeman
    Wisconsin
    You may be able to adapt it, but if I remember right the Mustang used a fiberglass resin taillight housing and the Mavericks is a metal housing. Ford used 2 very different bulb sockets for the 2 types - the fiberglass having a twist lock and the metal using springy clips. I hope that makes sense, the way I'm describing it. Take a look at a Maverick bulb holder and compare it to the Mustang harness and you will see what I mean.
    Eric J
  3. stayup760
    stayup760 Member
    1970 Ford Maverick
    but will the panel be a direct fit?
  4. stayup760
    stayup760 Member
    1970 Ford Maverick
