rear wheel bearings
Discussion in 'Technical' started by finn34, Mar 23, 2004.
  1. finn34
    finn34 Member
    Helsinki, Finland
    Maverick 70, ´39 Tudor
    Hi, have not posted for some time. But now a rear wheel bearing is giving up. My mav is a mid 70. It has the 8 in rear, seems to be original as it has 4 bolt axle flanges (that have been bored for 5). But the normal 8 in bearing does not fit. I measured the old one and it seems to be close to the bearing of a 7.5 in rear, but is it? Does anyone know. Could not find anything with search. This faulty bearing might be one reason for the exsessive roadnoise I complained about, the noise a rear bearing gives long before it goes is a little like roadnoise.
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    The old bearing itself will have a "bearing # itched on the race,this is a international number,it can be cross referanced to any manufacturer (timkin,SKS,NSK )etc. Get that number and You got the right bearing.
  3. finn34
    finn34 Member
    Helsinki, Finland
    That i tried to do but i did not remove the bearing yet and no numbers on the outher race. I wanted to go home from the garage. It´s not at my place. And you can still drive some miles, but not for long.
  4. Tom Laskowski
    Bay Area,California
    Here's two bearing #s both are Timken
    RW-207-CCRA
    RWF34R
    Any of these match what You have?
    These are from a four bolt wheel.
    Cost here is $13.99 and $24.99 USD,
  5. finn34
    finn34 Member
    Helsinki, Finland
    Yes the RVF-207-CCRA was the one, it did fit. Thanks. The catalogs do list the much bigger bearing for mavs 70 -.
    Now the roadnoise appears normal. Obviously the bearing did make more and more noise much before it went real bad. And soon i can enjoy some traction, spring is coming. It really goes.
  6. Tom Laskowski
    Bay Area,California
    Thats good news,glad You got it fixed,there's talk I maybe going back to Helsinki in August,I'll get You posted if i do. The place I go is in Tuusula, a company called Finn Aqua,bu I stay at the SAS Radisson in Helsinki
