Rear wheel stud help
Discussion in 'Technical' started by Bad Brad, Jul 5, 2015.
  1. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    So, I am running a 1/4" wheel spacer and would like to get that 1/4" back with longer studs. Anyone know the correct knurl size? I only get about 4 full turns before it gets snug, so I would feel safer if I get longer studs. I tried my local part stores, but they won't help if it ain't something they can just look up. Any advice would be great.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    .545" knurl.
    Bad Brad likes this.
  3. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    Thank you Larry.
  4. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I doubt it's gonna fit. You're talking over a tenth of an inch bigger. You can order longer studs from most of the mail-order performance parts suppliers.
  6. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    I figured the .560 was to big, but what about the .550. That's only 5 thousandths bigger. I have been searching like crazy and can't find a longer wheel stud in a .545.
  7. mercgt73
    mercgt73 Member
    Just order 1 and try it. If it works, you are good to go! Welcome to hot rodding. (y)
  8. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    Haha.. yea, I did order the .550's. If they don't work then I guess the search is on again. Or just tell the wife I just have to switch to the 9 inch now :)
  9. rthomas771
    They are 3 different part numbers for Maverick rear studs...70-73, 74-75 and 76-77
    Don't know any more that that other than 2 part numbers for the front studs...70-73 and 74-77. Making a total of 5 different part numbers for factory wheel studs.
    Only 2 different lug nuts...pretty and ugly.
  10. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    From what Larry told me and my research, the 74 will have the .545 in the rear. I can't find any aftermarket stud with that knurl. I'll try the .550 and see how that fits.
  11. Rasit
    Rasit Member
    SE Pennsylvania
    If you press them in it won't be a problem at all. If you plan on using a BFH it might require a little more persuasion.
  12. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    So, I had the local part store order those studs and when I went to go pick them up, they told me the total was $117!!! Needless to say, I did not get them! Lol.
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I paid like $35.00 for the ones I had.
  14. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    That's about what I was expecting to pay. I honestly can't find studs to fit my axles. 70-73 where one size. .625
    74-75 where the .545's.
    Then the 76-77 where back to the more comin size. .618
    Might just bust out a drill bit and go from there. :)
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Try first installing them without drilling anything.
