Red 72 comet 302 with a manual 4 speed
Discussion in 'General Maverick/Comet' started by Lucifer, Feb 4, 2023.
  1. Lucifer
    Lucifer Member
    Canada
    1972 comet
    Lacks a hood scoop and is there a special gasket for the back window? I thought I would goop it . That won’t work to well I don’t think maybe someone has done it. ? so please a line on how the back window sits in these cars if there is a rubber seal to get.
  2. 71gold
    Back Glass Seal - 2 Door Sedan - 1971-77 Ford Maverick
    Part #: D0DZ-6242084-A
    Features:
    • Exact of Original
    • High Quality Rubber
    • Correct 90 degree corners
    $49.95ea.
    Status: In Stock
    Dennis Carpenter
  3. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    DEFINITELY install it with the correct rear window gasket. Tat car is way too nice to end up with a rear window leak because you didn't install the rear window properly.
    Here's how it's done. It's really not that bad, especially if you can get an extra set of hands to help. Big windshields that wrap around a lot at the sides like a tri five Chevy are harder.
  4. Lucifer
    Lucifer Member
    Canada
    1972 comet
    Order it thank you so much auto crafter was not in stock
  5. Lucifer
    Lucifer Member
    Canada
    1972 comet
    Order thanks for the help
