remove shock towers
Discussion in 'General Maverick/Comet' started by mustangturbo50, May 26, 2008.
  1. mustangturbo50
    mustangturbo50 Member
    bettendorf, ia
    ok i have done some reading on here but have not found to much info. all i want to do is remove my shock towers? whats the best way to go about doing that . or is there a cheap and best way
  2. Mavman72
    If you remove the towers completely you will have to go to a different front suspension set up such as Mustang two or a strut type front suspension.Both have been done successfully on our cars.What most do is "notch" the towers to gain more room for headers and plug changes.
    Best way to remove them is to disassemble them from their mout points.Remove the bolts and spot welds holding them in place so as to retain the rest of the fender aprons.That way you still have something to attach your fenders too.
  3. mustangturbo50
    bettendorf, ia
    how much can i take off of them? i am making room for a 4.6
  4. Mavman72
    You can remove the whole tower and leave the aprons intact.just remember you lose the upper controll arm mount point when you remove em and will have to change the front suspension.
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    To put a 4.6 OR to totally remove the towers (which must be done for 4.6), you must go with a Mustang 2 suspension (or equivalent).
    Do a search for Mustang II, Stang 2, S2, Mustang 2, etc...
    There have been TONS of posts on the subject.
    You just haven't been using the right search words.
    Edit:
    Forgot about M2 and MII
  7. mustangturbo50
    bettendorf, ia
    i wouldnt mind going to a mustang 2 style but i guess my main question is can i just cut one out of a mustang 2 and put it in with some fabricating of course. but why do i have to buy one for 1500 bucks..
  8. ratio411
    ratio411 Member
    Pensacola
    Yes.
    You can swap it in from a Mustang2 or Pinto. Bobcat for that matter...
    The biggest drawback there is 4 lugs.
    So you have to buy 5 lug conversion rotors.
    Then there is the chance of getting a donor car with a worn out rack or springs that are wrong for your car.
    So now you need to buy a new rack, aftermarket springs to get the correct rate vs weight, and add the rotors as well as all the other parts to rebuild the brakes that might be needed. Hoses to calipers...
    Still probably cheaper, but you should take these into consideration and add up the costs along with the cost of the donor parts. Not to mention your labor finding/removing/transporting the donor car/parts.
    With the kits, it seems to me that you should get everything required, everything new, possibly a warranty, and the only labor you have to provide is installing.
    Just a thought.
    You should read what comes with the kits and make your own determination. I would think the kits are complete, but I don't know for sure as I have never been in the market for a kit.
    My .02
