Removing and replacing the fan
Discussion in 'Technical' started by marty robbins, May 29, 2005.
  1. marty robbins
    marty robbins Member
    Olympia, Washington
    1975 Maverick Grabber
    I need to replace my fan because one of the fan blades is cracking and ready to let go! I loosened the four bolts holding it on and the bolts pull out but they are touching the radiator, do I need to pull the radiator? I am not really wanting to do this, If I tap on the fan and the extender, will it come out enough to get the fan off, also I am thinking of using a flex type of fan to let it run cooler than the stock fan any suggestions? anyway thank's for any advise, this is for a stock 302 on a 75 Grabber, and is running about 190, it had a 190 degree and I put in a 180, radiator is recored and all new hoses, and I would like to have it run a little cooler. thank's Marty.
  2. igo1090
    igo1090 Member
    catonsville, md
    unthread all 4 bolts & tap the spacer with a plastic hammer. the whole thing should all be able to come out. just be careful of the radiator. put a sheet of cardboard in there if you want to keep from damaging fins & tubes.
  3. Camtemple
    Camtemple Member
    BC Canada
    Maverick
    I have basicly the same setup, i had to take out the rad to put on a new fan, but I did that when I got the rad recored. I went with a 4 row rad, and it cools just fine now :). I also went with a flex fan as well.
  4. 71gold
    "unthread all 4 bolts & tap the spacer with a plastic hammer. the whole thing should all be able to come out." (y)
    as far as the "flex fan", i am not crazy about them. i think the stock fan is a better choice...J.M.O...frank...:bouncy:
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The stock fan is better, and it actually is a "flex-fan". Aftermarket flex-fans do not cool as well as the stock fan in most cases...
  6. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    flexfan
    My car has an aftermarket flexfan already but knowing it gets hot here in memphis I put an electric 14" fan in front of radiator to push air into it. My car runs cool now. Some would call this overkill, but my motor thanks me everyday...:2cents: (y)
