Removing Compressor
Discussion in 'Technical' started by kukm66, Mar 30, 2008.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    I removed the bolts from the 2 brackets that hold the compressor in place. How many other bolts are there and where are they? Can I just leave the base support in place?
  2. scmaverick
    scmaverick New Member
    SC
    1975 Maverick 250 Eng.
    There are 4 bolts on the compressor’s base (have a 75 Maverick 250 engine, changed oil in compressor) took alternator off, couldn’t get bolts with it on, reached under compressor base plate to get to them. The two in front are easy to get to the two in back are a little harder used a 9/16” racket wrench. I took my low and high A/C hoses off while mounted on base
