Removing Door panel and clips without messing it up
Discussion in 'Technical' started by gdemopesq, Mar 13, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I am removing the bodyside molding and would like to know how to remove the door panels to get the bolt outs without hacking the doorpanels as the wood breaks off easily of messing up the clips for re-use? Are there any tricks to easily take the clips off?
    Any tips to get the holes filled? Can you melt in metal rod on a vertical door? Can I MIG weld the holes?
    Thanks
  2. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
  3. Craig Selvey
    No need to remove the door panels to get the outside trim off. The outside trim can be removed without taking off the door panels. There is nothing inside the door to access in order to get the trim off.
  4. gdemopesq
    Michigan
    72 Maverick 302
    Craig I want to fill the holes though. Can i do it from the outside?
  5. Craig Selvey
    There are no holes in the middle of the door if it is factory trim. Just need to grind off the metal tabs.
  6. gdemopesq
    Michigan
    72 Maverick 302
    Awesome- I thought it had bolts like in the fender. Havent looked above the rear wheels-are they tabs or bolts?
  7. Mavman72
    Rear quarter trim is mounted like front fenders,door only have 2 fasteners.One on inside dege of the door at rear(latch end) and one in same place at front of door,inside dege(hinge END)Rear quarter trim fasteners are accessed from inside trunk and behind rear inner side panels.
  8. Mavaholic
    If you have the thick LDO trim, that is correct. However, the factory thin trim does have holes.
  9. Craig Selvey
    I have never seen holes on doors for the thin trim either. :huh:
    Now I am going to half to go look.
  10. Maverick28
    Maverick28 New Member
    TN
    Maverick
    exactly where are the clips located to remove the panel, I know dumb question but i just dont understand exactly where the clips are located to remove
  11. darren
    They are metal push clips attached to the back of the door panel around the edges.
