Replace an i6 with an i6
Discussion in 'Technical' started by tririte, Jan 23, 2012.
  1. tririte
    tririte Member
    Pasco, WA
    73 Maverick
    Is there a list somewhere of what I need to replace if I am just putting the same size engine into the car? I did try to search the forum, but no luck.
    If there is one, please point me there, if not, please help me out. Pretend you're making a list for "auto repair for dummies." Thanks.
  2. Joe Dirt
    It will be a simple R&R job (remove and replace)
  3. rthomas771
    Not all 6 cyl were the same. They were some minor changes year to year. The exhaust manifold size and exhaust pipe, high or low mount starter and bellhousing. Other things like pre emission vs post emission timing gear set. Valve size, combustion chamber volume and different intake log size and shape were also changed through the years. The 250 block is a different animal than the 170-200
  4. tririte
    tririte Member
    Pasco, WA
    73 Maverick
    Good to know. I'll try to keep things simpler by sticking with a 250 if possible.
  5. tririte
    tririte Member
    Pasco, WA
    73 Maverick
    Thank you! Looks like more work than I want to do...I'll stick to a 250.
  6. Jamie Miles
    Alto, GA
    I've had a few
    I've personally had two 200's and a 250 in my car. To go from a 250 to a 200 I had to replace the bell housing, torque converter, flex plate, modify the exhaust down pipe from the manifold (the 200 is shorter) and swap the 250's thermostat housing onto the 200 (or just replace the upper radiator hose with the proper one for a 200). It is a direct swap other then that. Motor mounts are the same and everything.
    The water pump, water pump pulley, and the alternator brackets are not interchangeable between a 200 and a 250 IIRC, so you'd need to find a motor complete with those.
  7. captainmack
    captainmack Quad Door
    can you tell a little more of you situation???
    Getting a free motor or what??
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I would do the general maintenance items. The one I have for you would love a tune-up I'm sure. We can talk more when you call back.
    Pretty much, I have a runner I was going to scrap and saw the post where he showed his newly aerated block. I'd rather give it to someone in need than throw it away.
  9. tririte
    tririte Member
    Pasco, WA
    73 Maverick
    Thanks Rick! I'm excited to get into your old 250 and mine and see if I can make this car come back to life!
  10. RMiller
    Kennewick, WA
    You're welcome! I had many helping hands when I was younger and learning the ropes, it's my time to give back.
  11. tririte
    tririte Member
    Pasco, WA
    73 Maverick
    Got the new 250 mounted today. Next steps, clean it up, figure out what I need to pull and keep from the old engine, and slap it back together.
  12. RMiller
    Kennewick, WA
    Looks much better there than in the scrap heap!
