replacement distributer
Discussion in 'Technical' started by shayne95, Feb 10, 2018.
where to buy a good origanal distributer
  1. 71 gold
    0 vote(s)
    0.0%
  2. stephen
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. shayne95
    shayne95 Member
    Pt Richey, Fl.
    71 maverick grabber
    I got ripped off buy rockauto. I bought a cardone new aftermarket distributer with cap, ect complete. The cap was loose, poor quality ect. And it didn't work. The said i ordered the wrong part for my 71 maverick.
    I got ripped off by rock auto. I orderd a cardone new aftermarket distributer with cap, complete. The condensor was wrong size, cap sloppy. poor quality and it didn't work. Rockauto said i ordered the wrong part for my 71 maverick. There website said perfect fit. You can't even talk to live person. Case closed. I found a remanufactured one but it's cardone again. Auto Krafter is priacy. I want to stay original. Anyone have any ideas where to go? what say you frank 71 gold?
    Ronald Hopkins likes this.
  2. Krazy Comet
    What engine??? NAPA has rebuilt 302 dist for $53...
    Rebuilds from anywhere are probably sourced from Cardone...
    There are good new ones(at least electronic) from Summit, Jegs etc...
  3. 71gold
    Summit or Advance Auto...:bouncy:
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Those guys just sent me an upper ball joint that had been installed! Waiting for the rest of the order to show before I complain just in case there are more issues.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If you are in need of a new distributor why not go ahead and update to electronic ignition?
    Crazy Larry and baddad457 like this.
  6. RyanTravis
    RyanTravis Member
    Chicago Illinois
    1995 Buick Century; 1972 Ford Maverick; 1990 Cadillac DeVille; 1960 Chevrolet Bel-Air Sedan
    I want to get a electric Distributor for my 72 200ci, any advice?
  7. Hotrock
    Munroe Falls, Ohio
    You should start a new thread to get your question answered not tag on to a thread that is 6 months old. Good luck!!!
  8. baddad457
    Almost any distributor cap fits loose. You can fix this by bending the spring clips to tighten it up. You can also take some duct tape and line the distributor body where the cap sits to tighten up the fit. I'm running a reman 85 Mustang distributor in my Comet's 331. I'm using the 80's cap adapter and large post type EFI cap. It didn't fit tight either, but a quick tweaking of the spring clips fixed that. If you want a better quality cap, buy one separately. You'll always get the lowest quality parts when they're sold as a package. And you say it didn't work ? Why ? What was the problem ? How did you install it ? How did you set the points ? And finally, you say you want to keep it original, seeing as you're working on a 45 year old vehicle, your choices are becoming extremely limited in certain parts, you gotta pay to play here.
    mojo likes this.
  9. Krazy Comet
    The loose cap poster hasn't been seen since back in Feb. Apparently a drive by poster that stops in whenever they need something.
    Current question is where to get electronic dist for a '72 200. Already recommended to post another thread.
  10. baddad457
    As do many posters here. Sorry we bothered you.
