Resistor wire
Discussion in 'Technical' started by rmmpe, May 25, 2009.
  1. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    The ignition of the 302 in my REO is still points type and I like it because I can fix it in the field with a matchbook cover. BUT, it has a resistor wire and I haven't a clue what ballast resistor I could replace it with.
    Can anyone help me with this?
  2. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I hear people say that the dodge ballast resistor is a good replacement for it.
    If you ever went to solid state I bet you would never go back. I can still fix my solid state ignition out in the field as well I just have to carry a couple of extra parts.
    I am running a cross bred set up using the 4 pin module out of an HEI set up and a Duraspark distributor. Works well and easy to work on
    clint
  3. Jamie Miles
    I agree with Clint 100%. I'll never use points again.
