results of my compression test
Discussion in 'Technical' started by xpsnake, Sep 19, 2008.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    150 140
    139 150
    150 158
    140 162
    FRONT
    I know the 10% rule, so I'm just barely out of that, any thoughts?
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    What sorts of problems are you having that prompted a compression check?
    Maybe you need a valve job...:huh:
  3. xpsnake
    xpsnake Bruce
    This was preemptive, since I replaced the cap, rotor, plugs, and wires, it has been running a lot better, but it's still not running smooth.
  4. ratio411
    ratio411 Member
    Pensacola
    Points?
    Condensor?
    Does it have the original plastic cam gear on the timing set?
    Carb?
    Just some thoughts.
    I hate trying to diagnose via keyboard...
  5. xpsnake
    xpsnake Bruce
    306ci
    KB flat top pistons (with 6cc valve reliefs)
    eagle i-beam rods
    stock crank
    tfs stage 1 cam (.499/.510 w/1.6's)
    ASF 32 heat range plugs gapped 40
    1.7 roller rockers (changes the cam specs I know)
    hooker 6901 headers
    e7te heads, shaved ~9.5:1-10:1 comp
    weiand 4011 intake
    holley 600 carb vac 2ndary. #70 jets
    mechanical fuel pump
    pertronix in-dizzy ignition
    running ahead of a c4 and 3.00 open rear
    doubler roller timing chain.
  6. ratio411
    ratio411 Member
    Pensacola
    Oh, nevermind.
    I thought we might be talking about a stock engine.
    Actually I don't know why I thought that... I have seen your specs listed before. :doh:
  7. Thack
    Thack vision advicator
    Moreno Valley Ca
    I don't think it's that bad, you are planning on changing heads aren't you? You can do more investigating then. I would worry more if you went under 120.
    Did you try the oil trick in the low cylinders? Leak down test would be better too.
  8. Bryant
    in my experience with compression tests. the temp of the motor staying consitant is very important. if you lower pressures come in towards the end of the test then i would dismiss them as the cylinders have cooled off a bit and if the bat. charge has droped a bit cauisng a lower cranking speed. i dont see any real problem with those results. a perfomance cam can cause lower comprssion test results due to the valve over lap.
  9. ratio411
    ratio411 Member
    Pensacola
    Last 2 posts were excellent points.
    The numbers didn't concern me much because they were high numbers for a dry compression test, even if they are spread a bit.
    I like the idea of combining the last two posts...
    Keep a battery charger on the car to keep starter speed as consistent as possible.
    Do a dry test first.
    Then do a wet test.
    Then do a leak down.
    Keep a running tab of all the numbers, but don't analyze anything till all results are in.
  10. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    3 x agree+(plus) check push rods, geometry and rocker arm contact patch on the valve...since the e-7's where milled...possibility that a valve might,or be carbonized a little and flow a little less on that cylinder... last rebuild I did(72 302) with new cast pistons netted between 90>110 psi dry...with a CC 268H,8to1 mechanical compression and no issues...I aways go for 5 hits on the compression gauge...
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    did you check the rubber in ballancer
