Reverse Lights
Discussion in 'Technical' started by Cabinator, Apr 14, 2006.
  1. Cabinator
    Cabinator Member
    So Cal
    74 Grabber, 70 Maverick
    So can anyone tell me if the reverse lights are tied into the nuetral safety switch on the trans, or is there a switch somewhere else?:huh:
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    mine is on the steering column towards the bottom
  3. Cabinator
    Cabinator Member
    So Cal
    one wire in one wire out?
  4. Craig Selvey
    Some floor shift cars has the switch on the tranny.
  5. Cabinator
    Cabinator Member
    So Cal
    mine is column, id go out and look...but its raining....
  6. Craig Selvey
    Then your neutral safety/reverse light switch is on the column.
