Reverse rotation water pump
Discussion in 'General Maverick/Comet' started by Spillman, Sep 29, 2008.
  1. Spillman
    Spillman Scott
    New Port Richey, Florida
    1971 Comet 306
    I want to get the March performance setup with ac and power steering http://www.marchperf.com/pg74.html . Unfortunately I already bought a high performance regular rotation water pump and aluminum timing cover. :((Im trying to get all the parts before I build the motor) I now know I need a reverse rotation water pump and I guess new timing cover. I did a search but it seems all the engines everybody is working on are newer. Mine is a 1971. Does anybody know if these parts bolt to my engine.
    Thanks
  2. newtoford
    newtoford Member
    New Castle Delaware
    if you get the right cover and pump it'll bolt right up
  3. Spillman
    Spillman Scott
    1971 Comet 306
    Does anybody know what the right pump and cover is?
  4. newtoford
    newtoford Member
    New Castle Delaware
    reverse rotation and standard rotation are your onlu real choices. you need a timing cover drilled for a dip stick though.
    if the pulley set you want calls for a reverse water pump your going to need that and the cover to match
  5. Dave B
    Isn't it just the pump that's reverse rotation? I didn't think the timing cover made a difference? I'll have to have a look at the one on my roller block..
  6. newtoford
    newtoford Member
    New Castle Delaware
    i could have sworn the water "ports" in the timing covers were casted a little diffrently. i know the waterpump gasket is slightly diffrent depending on what pump your using
  7. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I went with the styletrack setup http://www.marchperf.com/styletrack_ford_sb.html . It has the reverse rotation pump and came with a timing cover. Apparently, there is a specific timing cover needed for the short nose reverse rotation pumps. Otherwise it would not have come with one. I looked it up on Ford Motorsports. Its listed and not cheap.
    I suggest calling March and asking. Tell them what you have and which kit you want to use. They will tell you the part numbers you need to make it work. I had to move to an e. fuel pump and oil pan mounted dipstick to make mine work. This specific timing cover does not have dipstick or fuel pump provisions. They will tell you all about it.
