roller cam
Discussion in 'Technical' started by maverickboy22, Oct 18, 2005.
  1. maverickboy22
    maverickboy22 Member
    Ellenton,Georgia
    1970 maverick 302,1981 f-100,
    can i use old hyd. lifters with a hyd. roller cam?
  2. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    I would buy new ones
  3. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    if you are talking non roller old hyd NO!!!!...but if there roller then yes if they look good and the roller are not bad or have hot spots
  4. EFIMAV
    EFIMAV Member
    Davenport Iowa
    if it is a new cam then new lifters would be a good idea but not totally necessary. If it is a used cam then use the lifters you have! if you sliding in the new cam and/or this is a total rebuild do you really want to go back in for a bad lifter?
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Please read the question.. Do NOT use HYD lifters on a new roller HYD cam unless the lifters are also roller. I agree with answer #2
  6. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    You would see the errors of your ways when your lifters drop almost an inch further in the block than you anticipated and nobody makes a push-rod long enough to reach the rocker arms. Roller Lifters are quite a bit taller than regular lifters ...
  7. EFIMAV
    EFIMAV Member
    Davenport Iowa
    my answer was only in reference to roller cams and roller lifters. In the case of flat tappet never reuse lifters on a new flat tappet cam. I have been running used roller lifters from one motor on a used roller cam from a different motor for years with no problems.
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    I am not convinced he has roller lifters..
  9. stmanser
    Davenport, Iowa
    why on earth would you want to use USED parts for an engine... i mean... SERIOUSLY... its not worth the cam or lifter failing prematurly... sure it can be done.... but why the hell would you want to risk it....
    dont get lazy and use old parts its just not worth it...
    Just my$.02
  10. maverickboy22
    Ellenton,Georgia
    i was talkin about using old stlye hyd. lifter instead of using the hyd. roller lifters.p.s. thanks for all the help.
  11. Mavaholic
    When I put my third cam in my engine, I went with roller. I got a set of used roller lifters from a buddy out of his 5.0 Mustang. New cam & used lifters. Been working great for over 3 years now.
  12. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I reused the roller lifters in my roller block too. Told the machine shop to check them out and make sure they were ok to reuse.
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    Reading the post again, it was not a question about using used lifters. It was a question about using hyd NON ROLLER lifters on a roller cam. Used or not, that will not work.
  14. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I don't think it will work also. Hyd roller cam need hyd roller lifters. Just my 2 cents.
  15. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Scotty, you're right. He indicated above he was talking about the old style lifters. Maverickboy, if you get a chance take a look at a roller cam "lobe" and a flat tappet cam lobe side by side. The roller lobe is far more aggressive because the roller lifter can handle the rapid ramp speed. If you put the old style lifter in with the roller cam you would probably shear the lobe off or the lifter off. Not sure which. If you need a set of used roller lifters I have a set that are in good shape that I would be willing to part with for a VERY reasonable price. I have the matching 93 cobra roller cam to go with them!
