Ron Francis wiring kit...
Discussion in 'Technical' started by 71gold, May 31, 2008.
  1. 71gold
    this is the complete wiring kit i had installed...(y)
    FORD POWERED EXPRESS WIRING Buy - XP-67
    www.ronfrancis.com/products.asp?dept=9[/quote]
    COMPLETE WIRING SYSTEM
    We supply you with connectors for stock Ford , ididit, Flaming River and other brands of steering columns. Wiring is included for the complete car - starter, one-wire alternator (external alternators add VR-99), points, Dura-Spark and aftermarket distributors. It will also wire the full gauge set including tach and neutral safety switches; and for all lighting needed for most safety inspections including Hi and Lo beams, indicator lights, parking, turn signal, brake and third brake light. The EXPRESS has been simplified over earlier kits to speed installation and facilitate trouble-shooting. We use HIGH TEMPERATURE fire resistant wire that is color-coded to the panel, each with the circuit clearly and legibly printed, supplemented by our famous COLOR CODED INSTRUCTIONS. An isolated cooling fan relay with wiring and a quality headlight switch are standard. A unique serial number for each kit allows us to provide technical assistance to you and any subsequent owner.
    Our newest custom wiring system is built specifically for your vehicle with all the connectors and wiring necessary to drive it, pass inspection, and be able to add accessories as you see fit, now and in the future. We have included the cooling fan relay & wiring. This is due to the fact that more and more customers are using electric fans. Now you can have everything centrally located for a cleaner installation! We've also added a Multi-Connection Battery Junction Block to reduce the number of wires going to the starter for all those add-ons in your custom application.
    *Clear Coated, Polished Stainless Steel Finish
    *18 Circuits on 16 Fuses
    *4 Select-A-Fuses
    *Faster Installation with New Style Terminal Block
    *Cooling Fan Relay & Wiring Included
    *Only the Best Quality Wire and Terminals
    *Proper Size Heavy Wire for Each Circuit
    *Handles 100 Amp Alternators
    *Serial Number
    *Includes the Proper Connectors & Terminals
    *Clear, Simple, Color Coded Instructions
    The Express is a direct replacement for all previous Ron Francis Wiring kits. It has a very similar bag structure to the past models. All variations of alternator, distributor and steering column are available. Along with the cooling fan wiring and the Multi-Connection Battery Juntion Block, it has 16 fuses, 4 of them select-a-circuit, for complete flexibility in building it your way. The 3-digit part number series harnesses indicate engine manufacturer. Some foreign applications are available.
    Dash ignition and floor dimmer switch users update to new reliable switches. Order RON FRANCIS WIRING Part # SW-37.
    If you have an externally regulated alternator we recommend ordering the Voltage Regulator (Order RON FRANCIS WIRING Part # VR-88).
    the only optional wire was the...backup wire...
    the guy that installed it had all the factory wire ends...with them he kept all the stock plugs.
    i ordered the...flat connectors...for the tail ligh sockets...this way the new wire ran into the socket and the new ends were installed...(no splices).(y)
    headlight plugs were done the same way.
    my AOD has a saftey/neutral switch...w/backup lights. AOD/OD lockout
    intermitten wipers... lights on/buzzer...power plug.
    i have a few pics. of all the wiring that was pulled out. we are installing the dome light w/map lights now.
    we should get everything done today...:thumbs2:
    thanks to: Markso125 for this diagram...:Handshake
    frank...:drive:
  2. Dave B
    Neat!!!
  3. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Killer!
  4. 71gold
    some stuff i replaced...
    this is one pile of wire...he had already thrown the rest away before i got a pic.
    ...Frank...:drive:
  5. rayzorsharp
    I like the heck out of that fuse box
  6. don graham
    Looks like a nce setup. Keep us informed as to how easy it goes in and how it works.:)
  7. 71gold
    it went in real easy...someone else did it.:thumbs2:
    we are rewiring the ...Dakota Digital...system now...:yup: he is making up a plug for them. this way everything will be...plug-and-play...:D
    and this way all the wires will be new...(y)
    David is a super nice guy and very much in the know when coming to wiring autos...:thumbs2:
    ...Frank...:cool:
  8. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Looks like a great wiring kit, way to go Frank.
  9. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    what is the price of the wiring kit??
  10. mavgrab302
    About $550.00 it is a nice wiring kit.
  11. 71gold
    that's real close...
    ...i edited the artical to include the diagram markso125 posted...
    ...:Handshake...
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
  13. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    cool Frank
  14. 71gold
  15. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    RIGHT ON!!! Thats the one for me:clap:
