Roof insulation?
Discussion in 'General Maverick/Comet' started by YellowStangDuan, Apr 6, 2014.
  1. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    Replacing my headliner, and the insulation is not reusable. What does everyone use? Looking for cheap too.
  2. blugene
  3. Dave B
    Dynaliner would be better. It's lighter.
  4. blugene
    I have also seen some reflective bubblie stuff at the Home Depot. But that stuff may not help absorb noise very well.
  5. YellowStangDuan
    Arlington, Texas
    71 Grabber
    Where can I get dynaliner?
  6. Dave B
    anywhere that sells dynamat, it's made by the same company.
  7. blugene
    $35 to $50 on ebay..
  8. 71gold
    peel n seal here...was good for...heat and sound...:bouncy:
  9. rthomas771
    x2 on the Peel & Seal
  10. Dave B
    Well, it is roofing material.....:rofl2:
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    Do you guys using the peel and seal have a rough idea on how much that amount of material weighs? Less than 3-4 lbs?
  12. rthomas771
    I posted the weight a few years ago. I think it was 4 lbs a roll or close to it. One roll does 96.7% of the roof...or a 2" strip to finish if you lay the P&S door to door.
    edit: 4.5 lbs. a roll
  13. YellowStangDuan
    Arlington, Texas
    71 Grabber
    I checked up on the peel and seal on other sites, some say the glue will turn loose in the heat. Being in Texas worries me about the heat.
  14. 71gold
    what's under (above) new car headliners...:huh:
  15. 71gold
    what temp do you think it would "fall off" at?
    I've had Peel N Seal in my car for about 5 years...inside the doors and quarter panels...no problems...:thumbs2:
    most people that bad mouth it...have never used it...:rolleyes:
    ...I guess it's time for another...test subject...
