Rust repair panels? Any known donors?
Discussion in 'Technical' started by Wantamav, Dec 9, 2006.
  1. Wantamav
    Wantamav Located in Macomb Mi.
    Michigan
    '71 2 door
    Are there any known rust repair panels (floor, eng compt, Qtr inner...) that can be retrofit to the Maverick. :huh: I'm not asking for plug and play, but is there is a certain year Mustang floor panel, for instance, that requires less work then others? I'd rather start with a good stamping (including stiffening beads) then try to work flat sheet. Please reply if you have personal experience that may be helpful. (y)
    Thanks!
