Seat belt warning buzzer?
Discussion in 'Technical' started by orl2swh, Jul 20, 2011.
  1. orl2swh
    orl2swh Member
    Orlando Fl
    1973 Maverick Grabber
    I changed out my front seat belts to a newer style. I did not reconect the conectors to the seat sensor and the new seat belts were not setup for this. It seamed to have worked untill now. I am getting a random buzzing when I roller over a bumb. It will buzz for a while and go out. I am guessing I have a wire shorting in this system but i do not see this system in the digram I have. Depending on how it is wired I am looking for the easy way to disable it. I am not sure but it looks to be a difficult to reach the buzzer.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    First check the wiring. It could be the wire going to the seat belt. The buzzer is locate on the right side of the dash above the clove box.
  3. rthomas771
    You got one now (y)
  4. orl2swh
    orl2swh Member
    Orlando Fl
    Thank you for the diagram. Not sure why they run it through the back up light switch. It apears that if I rmove the purple -white from here It would remopve most of the wiring which should eleminate the problem
