Seatbelt Interlock Wiring
Discussion in 'Technical' started by fastback86, Feb 4, 2009.
  1. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    I don't know if anyone else has this info but I bought some pages from a 1970-1974 factory wiring manual and it has the wiring diagram for the "yellow box" under the dash in '74 vehicles. I bypassed mine a while back by in a trial and error fashion probing the wires and finding which one went to the solenoid and which one came from the ignition switch. All I did was unhook the box, cut 2 wires from the connector and splice them together, and throw the box as far as I could. Looking at the diagram you can do the same thing under the hood at the override switch. Basically you connect the W-PK wire (white w/pink stripe) to the R-LB (red w/light blue stripe). I marked the possible modifications in red. Use at your own risk.
