sending unit float arm...
Discussion in 'Technical' started by 71gold, May 11, 2020.
  1. 71gold
    my new sending unit came with 3 float arms...:yup:
    A-is for a 16 gal. tank...7 " deep
    B-is for a 20 gal. tank...8" deep.
    C-is for a 22 gal. tank...9 3/4" deep
    my question is...
    if I use the A (16 gal) arm in a 20 gal tank will the gauge read empty before it gets empty?
    ...:bouncy:...
  2. yellow75
    Tillamook Oregon
    Would it depend on the depth of the tank, in theory it should read empty before it gets empty. If it were me I would use A as I would much rather have gas in tank then let it get empty
    71gold and mojo like this.
  3. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Considering these go in from the side on the lower part of the tank, I would suspect it would read full till you burn some gas down a little, so I would think that you would lose the ability to monitor the top end of the usage on the tank.
  4. krelboyne
    krelboyne Remember
    Salem, Oregon
    Do you have a link to the fuel tank sending unit you purchased?
  5. 71gold
    I have a 1966 Mustang sending unit in my car now. I saw this last night on the Summit website so I went today and bought it. it looks like it will work well with my Pro Flow 4 multi port EFI system. I mocked it up today and it will fit perfect. as stated it comes with 3 different float arms. so now I'm trying to decide what one will give me a little extra gas at the empty reading on my Dakota Digital fuel gauge. if it works this should make EFI swaps a littler easier for the Mav/Comet world.
    Holley 12-305
  6. 71gold
    as long as it reads right on the empty end all will be good. my new truck reads full for the first 150 miles from a fillup...:thumbs2:
  7. 71gold
    looking further I see the Maverick tank I have is 10 1/8" deep. so maybe the 20 gal. arm B would leave a couple of inches of gas...:huh:
  8. 71gold
    I went with the A-16 gal float arm. put 5 gals in the tank and gauge read...25%.
    I'll know more after I drive it...:chirp:
  9. 71gold
    the e-pump/sender came with a 4 wire pigtail 2 of them were for the fuel gauge.
    today I took the plug from an old sending unit and made a plug to use with the new sender.
    I soldered a connector to each post to be able to connect it to the stock sending unit plug.
    now need to wire the fuel pump to the relay and...:drive:...:chirp:
    Earl Branham likes this.
  10. 71gold
    got everything wired and plumbed today.
    fired it up and all is good.
    road test tomorrow...:drive:...:chirp:
    Earl Branham and mojo like this.
  11. 71gold
    don't like the ...16 gal. arm...it went from 15% t0 1% in about 3 miles. I drained the tank and it still had 2 gals. in it. it just moves a little fast for me...LOL
    I'll install the 20 gal. arm later.
