serious suspension upgrade time
Discussion in 'Technical' started by fastbackchaseca, Sep 6, 2011.
  1. fastbackchaseca
    fastbackchaseca Lead Troublemaker
    Los Angeles
    '72 Comet, '56 F-100, and "88-0232"
    So my amusement with the oddball Torino disc brake conversion has worn off. I made it work, had a ball, but it's time to get serious. The next undertaking involves engineering an entirely new double wishbone front end. I need to find a front spindle that will a) work for a suspension design like i'm after, and b) has readily available aftermarket disc brake/hub setups with a 5x4.5" bolt circle (ie wilwood). I'm not sure if I should be looking into a circle track spindle, or something else similar. Any input?
