shackle ext?????
Discussion in 'Technical' started by 71nogo, May 20, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    can someone tell me am i asking for the right item name? i would like to raise the rear end about an inch or two. i have seen this done before. im just not sure what this is called. or where to get them. the girlie at jc whittney thought i was insane. someone on this site has done this im sure.:oops:
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Save yourself the headaches and get new springs instead.
  3. maverick75
  4. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    new springs, if you don't want to mess with them for years.
  5. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    truth be said, im not sure i want to go through all of that. i thoght there was an after mkt item that one could buy to give the car just a little boost in the rear end. Air shocks are not an option for me as i can see the damage they caused the previous owner with a big rip in the floor board between the trunk and back seat. i just dont waant it to loook like the trunk is loaded down with grocery's.
  6. maverick75
    I know what your looking for, its those longer shackles that they sell.
    I'm not going to recommend them though because they dont fix anything. And actually end up giving you more problems.
    Just buy some new springs from here for $109
    http://www.generalspringkc.com/index.php
    or get some $40 econoline junkyard springs .
  7. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    can you tell me what kind of problems?
  8. Bob Wiken
    Fayetteville, Arkansas
    here is another possibility. I'm going to use these to lower my car as i have the opposite problem. (front is too high). I think new springs is the safest and best way to go though. These are from Autozone.
    Superior Automotive / 2 in. U-Bolt lift or lowering block kit
    [​IMG] PREVIOUS | NEXT [​IMG]
    Price: $29.99
    AVAILABILITY:
    STORE PICK UP
    AVAILABLE
    Normally stocked at your local store.
    SHIP TO HOME
    AVAILABLE
    Ships within 2 business days.
    Part Number:13-1030Weight:7.05 lbsDescription:U-bolt lift or lowering block kitSize:2 in.
  9. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    RIGHT ON BOB!!! I'll give autozone a call right now.:thumbs2:
  10. maverick75
    http://mmb.maverick.to/showthread.php?t=58409&highlight=spring+shackels
    That kit will not work for you.
    It lowers if the axle is on top of the springs like your car has
    It only lifts when the axle is on top of the spring , like in some trucks.
  11. maverick75
    Longer shackles :
    Block kit:
  12. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    AND I THOUGHT THERE WOULD BE A SIMPLE SOLUTION TO THIS. F-O-R-D:mad:
  13. maverick75
    it's the same thing for Pontiac, Chevy and Mopar.
    Fixed it right the first time and it should give you plenty of trouble free years (y)
  14. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    I have always had pontiacs. mods and repair was always pretty simple.
  15. Craig Selvey
    Simple fix.....yes.
    CORRECT fix.....no.
    Shackles are a no-no.
