shaking on highway
Discussion in 'Technical' started by maverick656, Dec 2, 2014.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    I have a 75 maverick 250i6, and when I am on the highway, when I hit 60-70 mph on the interstate, to pass someone, my steering wheel starts to shake pretty bad. And it's a pulsating vibration, as in it come in predictable sets. Any clue what could be causing it? Motor mounts?
  2. Mavman72
    Wheel balance is off... Or a warped rotor...
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    The tires are probably out of balance.
  4. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    I just had the tires balanced and the rotors aren't warped. Those were my first thoughts. Ujoints maybe?
  5. Krazy Comet
    Doubtful, steering sector may have excessive play and/or idler arm or other steering component is loose... Also a tire can be out of round and still balance but shake at speed...
  6. yellow75
    Tillamook Oregon
    I had the same problem and it ended up being the idler arm, more than likely it is a worn component in the steering
  7. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Where is the idler arm exactly on the front end?
  8. mojo
    I suggest taking the car to a competent shop/s and have the entire front steering and suspension inspected. Most likely in these 40yr+ cars most if not all of these components need replacing/upgrading.
  9. Craig Selvey
    Idler arm is on the passenger end of the center link.
  10. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    Is there a brand yinz prefer? I don't wanna buy the duralast brand, I've had nothing but trouble with them
  11. Bryant
    moog is the best, they even have a problem solver line that improves on the factory deficincys in design. they used to offer a upper control arm bushing problem solver kit but its disconinued about 2 years ago last i checked. i was able to find some of them in stock at rock auto. they also offer a problem solver idler arm. i havent checked on its availability recently.
  12. Bryant
    i found the moog problem solver idler arm part number: k8245
    it appears to still be available.
    this replaces the rubber bushing with a greasable bearing. i would highly recommend everybody to do this upgrade.
  13. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    It says it's not greaseable..
  14. Bryant
  15. Krazy Comet
    The one I installed on my Comet is greaseable...
