shaved shock towers Question
Discussion in 'Technical' started by mustangnut68, Jul 13, 2006.
  1. mustangnut68
    mustangnut68 New Member
    Hi Iam getting ready to put a 351 w in my maverick,, and I was wondering how much do I cut out of the towers, is there a set amount like 1 inch deep and 7 inchs down ???? Let me know,, thanks steve
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I don't know if there is dimensional data per se on where to cut - "you just know".
    Here's how I did mine. Some started closer to the shock itself than I did at the top, but most of us stay 1 to 1-/2" above the A-arm bolt holes.
    Good luck and keep us posted.
  3. rayzorsharp
    Hey Rick, that's a pretty cool mural you have painted on your shock tower. It almost looks like tool laying around on a shop floor or something. (y)
  4. Rick Book
    Rick Book Member
    Thailand
    Ha! I've got a better one where there is a welder's gove laying on the ground. It looks like I cut my hand off! :rofl: (will look for it when I get home).
  5. mustangnut68
    Hey thanks alot for the info, Its just exactly what I needed to know,, Good picture..,, Thanks Steve,,
  6. Mavaholic
    I've done 3 and I always shave it to where I only leave 1/2 to 3/4" between the spring and the plate that gets welded in there. Also only leave about 1/2" above the A arm when its in the upper most position.
  7. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    What thickness is the metal that you weld in place of the cut part?
  8. Mavaholic
    1/8" plate steel.
  9. Rick Book
    Rick Book Member
    Thailand
    Here's one more (hand cut off) :rofl2:
  10. Mavaholic
    Damn, thats gonna hurt. A little duct tape and it will be good as new. :D
  11. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Since my shock towers are not hairy, I see no need to shave them...
  12. 71gold
    good one T.L.(y)
    why do people refer to it as "shaving" :hmmm:? ....isn"t it "notching"??:huh:
    ...frank...:bouncy:
  13. scooper77515
    I cut a little deeper than most, and used a little thicker steel (3/16", I think). I just made sure I had a good 1/2" clearance of all moving parts and suspension/springs.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    just a question about this one, would I have to remove everything down to only shock towers or could I make the cuts and welds with the springs and engine in place?
    thanks
  15. rayzorsharp
    I've never cut towers but there is now way I would try it without removing everything. I really don't see how you could do it anyway. You've got to get in there and do some serious cutting and welding and you've got to have room for that.
