Shim the upper control arm??????
Discussion in 'General Maverick/Comet' started by 55crownvic, Jun 5, 2017.
  1. 55crownvic
    55crownvic Member
    colorado springs
    Who has done this, and how well did it work?
  2. mojo
    I shimmed my stock UCA last year to get the car's caster out to 3+ degrees specified by Borgeson to get the car tracking straight, be4 that it was hair-raising experience. I have 2- 1/8" shims on each arm; I have had no issues to date. The only reason I cud see adding shims is to get more caster cheaply. I have put approx. 2 K miles since shimming and no issues. I probably will check to make sure nuts are holding tight -- just for peace of mind...
  3. 55crownvic
    55crownvic Member
    colorado springs
    thanks for that mojo, did you have the car re-aligned after adding the shims, or just drive it? Have a friend that is trying to figure out why his car is all over the road, even after an alignment.
  4. Krazy Comet
    I also have two 1/8" shims under front bolts on each side of mine, plus strut rods are adj to give max positive caster... No idea what actual settings are but it drives decent...
    Any change in caster or camber will throw toe in out of spec... I adj toe by using my Bear alignment board that measures toe in/out, as long as toe is close to spec there won't be a tire wear issue...
    Usually wondering /instability is caused by too much toe out and/or not enough positive caster...
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    We also have a Borgeson PS unit on a 72 Maverick . We added a Quarter Inch steel shim and our caster is about three and a half degrees. Then we had it " Aligned " .. we recommend the alignment to insure everything up to specs. Car drives like it's on rails !
    Cometized
    (Chip)
  6. tody
    tody Member
    cologne, germany
    same here, had to add shims to get it to my preferred spec. when you add shims, you will definitely need an alignment.
  7. 55crownvic
    55crownvic Member
    colorado springs
    did you take out the spring or just loosen the a arm bolt and slide the shims in?
  8. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Crownvic:
    We shimmed the Maverick when it was being disassembled and the spring wasn't in place at the time.
    Cometized
    (Chip)
  9. rthomas771
    60-65 Falcons use shims on the upper control arm as do 65-66 Mustangs. No need to remove spring to install shims. On a side note...they also have more threads sticking through the shock tower.
  10. mojo
    g
    That's interesting to know Falcons/Stangs had shims in A-arms. I had no idea Ford used shims in 60's era cars.
    A lot easier installing shims in many GM suspensions of the same era. I appreciate the fact they can be installed from under the hood instead of fender well.
  11. Krazy Comet
    I loosened both nuts and pried the arm assembly away from shock tower till they fit(wire or tie shims together)... Tightened it all back in place...
    There should be enough threads to allow for two shims and still tighten nut fully..
  12. 55crownvic
    55crownvic Member
    colorado springs
    just got it done, without removing the springs, was very hesitant tho. Only had enuff threads for one 1/8" shim on both front bolts. Wasnt comfy enuff to try 1/4" . Will try and drive it tomorrow and see if just that much helped.
  13. mojo
    Are you putting these shims on a Maverick/Comet? W/ stock arms I have a few threads protruding from the nuts; probably cud have got another 1/16" shim w/o discomfort.
  14. 55crownvic
    55crownvic Member
    colorado springs
    This is a 70 mav, were not enuff threads to go 1/4".
  15. Krazy Comet
    Did you shim both front & rear??
    Shims to increase positive caster are only added to front on each side...
